Panel lights out?
Old 10-13-2014, 10:02 AM
Roy Mander's Avatar
Default Panel lights out?
My 64 has a problem with the dash panel lights. They all work with the exception of the lighting around the two rotating ***** controlling the fan speed and the air flow direction. The control **** that controlls the illumination does not make any difference. How can I get access to change the bulbs if they have blown, or is there a better explanation on getting them to work, Thanks.
Old 10-13-2014, 10:42 AM
Default Re: Panel lights out?
book says :
The Heater Switch (3) is illuminated with LEDs whenever
the headlamps or marker lamps are on. The lamp
brightness is adjustable with the dimmer switch
located in the Instrument Cluster. The heater switch
LEDs cannot be adjusted or repaired. If faulty or damaged,
the entire Heater Switch Assembly must be
replaced as a unit. For complete Heater Switch
removal procedures, refer to the Heater Control
removal in the Heating and Air Conditioning section.
(Refer to 24 - HEATING & AIR CONDITIONING/CONTROLS/
HEATER CONTROL - REMOVAL).
But I would think, if none of them light up, it is a circuit problem, not a led problem.
I've never dug into one of those control modules, so that's all I have to add.
( and I hope you meant 2004, not 64 )
pioneer4x4
07-01-2021 10:56 AM
PNA
11-12-2020 04:44 PM
pioneer4x4
03-25-2019 10:35 AM
PHeez
08-11-2015 01:30 PM
Mopar or No Car
08-11-2015 08:11 AM
Quick Reply: Panel lights out?
