AFAIK i bumped the stock srt6 et record today
went 13.044@108.19 at norwalk today in the heat (85f) @ 2:48 today, i'm positive it would have broke into the 12's if i would have stuck around for the cooler weather that came in (66f) tonight on the way back to michigan. so the baseline is set for our shop car, time to start building the mods, is the current modified ET record really only 12.5x as shown on dragtimes.com??? if so give us a month or 2 and that should get bumped as well, good things to come!
Re: AFAIK i bumped the stock srt6 et record today
You make the parts and I will buy them! I'm on a mission to get my car into the 11's. What do you think about making a pulley kit that bumps up boost
~ 5 psi, instead of everyone else's ~ 3 psi. Especially if you're going to run meth/water injection I know you won't have any timing or detonation problems.
Well hurry up and get some goodies on the market and keep up the good work.
I know this car can break into the 12's stock...With everyone turning around 106-108 mph, that is good enough to be a 12.5 car. The problem lies in 60 ft times. It's a slug for the first 10 ft, but when the supercharger kicks in its a whole different story. lol. I bet with a little looser converter this thing would tear it up! Great time though!
I believe there is already a guy running in the mid 12s right now. Your gonna need to experiment with the methanol injection, I would pick up Bosch's stand alone ECU if you want to adjust your timing and fuel curves. It has aux port for Fly-by-wire throttle and traction control adjustments. Go for it dude!
Blast! Take over my top spot will you? lol. I ran 13.06@109 mph 100% stock with the all-season continental tires at US41 in May...
I'm ordering new tires soon, Hoping to break 12's on street tires and 100% stock set up. I'll be going with the BFG KDW's.
Yup... some of my crew from CSC out there... i was going to go when it was scheduled for fall... and so i made plans for other things for the first part of summer, so when it was changed to this past weekend, it kinda was a no go for me.
What tires did you run on?
trac off for burnout, track on for pass (never engaged on the 13.0 pass), in drive (autostick was slower et's). we got about 25 passes in that day trying different combinations, found 32 psi to be the sweet spot for the rear tires, anything lower then that would hurt the trap speeds and did not help the et's.
the passes when the TC did engage my ET's were 1/2 sec slower.
I have bought stuff for my srt-4 off srtforums.com from you guys.
i'm working on the intake right now, found/eliminated a few restrictions so far but i'm not finished with it yet, then exhaust at the very least. got anything else in mind?
