Do you want a Keyless Entry Alert Tone?
Re: Do you want a Keyless Entry Alert Tone?
Speaking of disconnecting your battery, it's a bit of a pain in the butt disconnecting the battery every time i want to "mess" with the electrical system. Has anybody on the FORUM ever installed a battery switch similar to the ones used on boats or race cars? I was looking over locations last night, and checked out the battery wiring. It should be fairly easy to do...and relatively inexpensive.
cheers,
Ted
cheers,
Ted
The settings of the pollution controls used for smog checks get unset and you have to drives miles to reset them for a clean air test. The light on e dash for the steering control system (?) may come on and need resetting, mine does not but some say it does. Not worth the effort is my belief.
Hey Young Fella!
I got that steering alarm thing after disconnecting the battery to wire up the footwell lights. It took a while for the indicator to go away. A real pain in the proverbial butt. I'll take your advice, and be careful when doing further electrical stuff. The only exception will be if there is the possibility of setting off an airbag. KABOOM!!
cheers,
Ted
cheers,
Ted
on
I seem to remember once (yeah ONCE) taking off the POS cable 1st, and the dang alarm went screaming loudly. I don't know why I did the POS, I usually was smart enough to remove the NEG cable first (like your supposed to on a NEG grounded vehicle). Anyway, I digress, IF your going to install one of those battery cut-off devices, I would suggest you install it on the NEG side, so the alarm doesn't go screaming.
I've been scratching my head over your "Dang Alarm"...and why it would sound with the battery disconnected. Perhaps a large charged capacitor supplied juice, or something like a Garmin GPS with battery power might back-feed somehow? Strange.
When installing a battery switch in a marine application, normally one puts it into the positive (+) side of the circuit. Here we have a Canadian version of AYBC regulations:
https://www.tc.gc.ca/eng/marinesafet...ection8-67.htm
See 8.6.2
cheers,
Ted
See 8.6.2
cheers,
Ted
See 8.6.2
cheers,
Ted
See 8.6.2
cheers,
Ted
Presumably you can remove the siren from the cars wiring and get the alarm going, how I do not know. But when a battery leaks it can trip the alarm as the PCB is eaten away by the acid, some how that can trigger the alarm by destroying some of the circuitry in some cases, not all.
Hi this is Mike. I am new to this forum and do not have a clue what I am doing. Let me start with a question. I would like to install the Piezo buzzer to my crossfire to get a tone when I lock the door. The fuse box in the diagram is on the opposite side on my crossfire . It is not the same box. So I am wondering what I am looking at. I need the locate the relay plug in my fuse box. Can anyone help?
Im not familiar with the buzzer you installed. Most have used the Mercedes siren, that give 3 chirps ,when activating the alarm. About $150 but if you have the factory siren on the car , it won't be long (search this) before it becomes the "cricket on crack"...lol...
Do these need to be wired positive to positive and negative to negative. Just wondering, I have never studied them at all.
Yes they do.. my first rodeo.. hmm.. I think I need a louder buzzer . picked up another one with same "faint" results.. tested with a battery and that is when I found out..
