Battery time
Re: Battery time
$149.00 from Search Results : Tri-State Battery Warehouse
The bimmer forum says they do free shipping, but I don't see that on the web site.
Re: Battery time
Franc
I replaced the original Varta with an Interstate brand battery. The link below is a newer model than mine and has greater cranking power. There was a sale at Firestone and did a cash and carry. At that time I believe it was about $110.
I have been satisfied with the battery over the past two years.
Dennis
DTMenace
https://www.interstatebatteries.com/...tery_V6%2f3.2L)
Dennis
DTMenace
Re: Battery time
Franc
Dennis
DTMenace
https://www.interstatebatteries.com/...ery_V6%2f3.2L)
Dennis
DTMenace
I am a fan of interstate batteries for along time. 'causethey seem to last a long time. thanks DTmenace
And thanks to others as well.
I'm likely selling the roadster this year, so I prefer to go with the lower priced unit.
Re: Battery time
Just for the information (dis) and fun I re-posted this for you, Woody Enjoy
https://www.crossfireforum.org/forum...-taaadaaa.html
on
Re: Battery time
Been using the Shuriken BT-20 in my Limited for over 3 yrs without a single hiccup. Only 13.5 lbs, under $100 and free ship!
SHURiKEN SK-BT20 (SKBT20) 850 Amp 12 Volt AGM Power Cell Battery
SHURiKEN SK-SAE20 Pair of SAE Posts with M5 (SKSAE20)
on
Re: Battery time
My GAWD, I can't believe this battery works so well! Wow!
on
Re: Battery time
on
Re: Battery time
She was my daily driver until I got the SRT. Now the wifey drives her about every other day and she usually sits all weekend. The dry cells usually have a pretty good retainment when not being used. I have the same type battery on my Vulcan 1500 and it has sat for 3 weeks at a time and would then fire right up. Coarse there's nothing on the bike to drain the bat like the car does. I've even seen where they have been mounted behind the passenger seat freeing up the space for a Killer Chiller tank, Meth, NOX or what ever your flavor. They are totally maint. free and spill proof and can even be mounted upside down!
At one time they were good enough that Rob was carrying them @ Needswings, but I don't see them there anymore. Been meaning to ask Rob if there was a reason why. He even used to sell a custom LED pad made specifically for this battery...
https://www.crossfireforum.org/forum...ntrayblue1.jpg
They are probably more popular with the racers because of the huge weight savings, but it has been no problem at all replacing the heavy OEM Varta. I put a thick rubber pad under it and use a nylon strap with hooks on the ends that are made for marine batteries to hold it in place.
And as a testiment to how good it's been, the car has cranked up perfectly since new!
on
Re: Battery time
Ya Doc, these might not be that great for the SRTs, with the problems I've seen with the over volting/speeding the alternators when pulley mods are done.
On the Limited I also replaced every lamp with LEDs and HID headlights to drop the voltage suckage. Might be why I've gotten such great longevity.
on
Re: Battery time
When it comes to batteries you just cannot beat a battery with lots of lead in it when it gets cold.
Lead = Power.
These little batteries may be OK in the warm climates but they pack 1/3 the power of a battery suitable for cold climates.
If you want to save weight, go on a diet.
Lead = Power.
Re: Battery time
Lead = Power.
Lead = Power.
Re: Battery time
Well the stellar battery is one of the best hoaxes I have seen, the attention to detail was outstanding . The paper work the packaging wow. I did recognize the green base a industrial electrical component possibly from a motor control center. Of corse what gave it away was the words in English LINE as in line load on the base , And the CSA stamp on the terminal lugs .I suspect that the buss style battery's are made of BX or something similar .i am in total Awe
Cheers
Mongoose57
Cheers
Mongoose57
northwest_crossfire
05-30-2016 05:19 PM
BrenLW
08-05-2015 04:53 AM
cx24724
07-12-2015 11:57 AM
FIXRE
07-09-2015 09:16 PM
