Goodyear 285/35 wider than PS2 285/35
I just got new Michelin 285/35' put on the back of my car and they really didn't look hardly any wider than the 255/35's. I got under the back of the car with a tape measure and from outside to inside I came up with 10.5 inches, so then I measured the 255's that came off the car and came up with 10.5 inches. I know with one mounted on a rim and one not could make a little difference and then of course measuring by eyeing a tape measure could be a little off too. But then I measured a pair of Goodyear F1 285/35's that I have and they were 3/4" wider than the PS2's. The 285 PS2's are right at an inch taller than the 255's and they right at the same height as the Goodyear 285's. You can tell they are a hair wider by looking at the rear of the car, but they don't even look close to as wide as what the Goodyear's did on the '04 coupe that they were on. Truthfully the new PS2 285's look like what should have came on the car. I wish I had that one to over again, I feel like I just wasted $860, the car does look better but not $860 better.
on
Re: Goodyear 285/35 wider than PS2 285/35
Originally Posted by MMZ_TimeLord
Wow... that is crazy... Now I'm not sure I want to go with PS2s when I go to 295/30s in the rear... probably won't be all that much wider of a footprint than the stock ContiTouring 255/35s...
on
Steve,
I'm going to do some measurements on the Pilot Sport A/S tires I have on now and give you some numbers this evening or tomorrow morning.
I'd like to think that your measurements are off, but seeing as how I don't have the stock rims and tires anymore, I can't verify that...
I am planning on putting at LEAST 295/30R19 tires in the rear... maybe I can find a shop that actually has those in stock so I can compare them BEFORE I buy.
Unfortunately, Michelin's site specs for the PS2 state that the 295/30R19 tires are only for 10 to 11 inch wide rims... I'm betting they can be squeezed onto a 9.5 inch wide rim, but I'll have to check with the shop to see if that will create problems. EDIT: Tire Rack states that it will simply be harder for the shop to mount a 295/30R19 on the 9.5 Inch wide rim... not impossible and it will not create issues.
NOTE: Goodyear Eagle F1 GS-D3 tires only go up to 275/35R19... otherwise the profile is even higher. Goodyear Eagle F1 Supercar tires only go up to 285/35R19 or 325/30R19 if you want to purchase a wider rim. Goodyear Eagle F1 GS tires aren't even made for 19 inch rims. Michelin PS2 tires have many more size choices available, probably due to the popularity of the tire.
EDIT: Various posts state that 245/35R18 tires will rub the upper A-Frame bolt. So I may have to reconsider the 255/35R18s I was looking at for the front of this beast. Either that or figure a way to 'trim' that bolt or possibly turn it around. I'll be doing the clearance check sometime this week.
Steve,
xfireohio
07-20-2020 12:03 AM
velociabstract
28
10-28-2015 12:46 PM
cjfine
07-20-2015 11:58 PM
