Old Aug 31, 2025 | 11:45 PM
M60A3Driver
Default Re: Died misteriously while driving - any ideas?
Originally Posted by CaptArt
Battery was replaced just before alternator had to be replaced, now fully charged and system working perfectly as specified. Car was running when attempt to lower top took place. Yes, I do know how to do manually, but as I said, that won't make much difference now that engine won't continue to run.
As far as the engine not running, have you tried replacing the RCM (relay control module)?
The fuel pump relay is inside of it. These relays as well as the solder joints are failing due to age. If you don't know what I'm referring to, check out this post: LINK to RCM replacement
NOTE: It is not necessary to disconnect the battery to replace the RCM.
