Old Sep 1, 2025 | 11:37 AM
CaptArt's Avatar
CaptArt
Default Re: Died misteriously while driving - any ideas?
As far as the engine not running, have you tried replacing the RCM (relay control module)?
The fuel pump relay is inside of it. These relays as well as the solder joints are failing due to age. If you don't know what I'm referring to, check out this post: LINK to RCM replacement
NOTE: It is not necessary to disconnect the battery to replace the RCM.
I had replaced the original rcm with a one modified with the "I'm so horny" mod, when I previously encountered problems. Then that one hiccuped and it was sent back and repaired and everything seems to be good. Questioning whether or not engine the would even start if the rcm was again having issues, I didn't think it to be the cause. Imagine my surprise when today, I swapped it out with a new one I keep as a spare and the engine fired up and ran fine. Didn't fix any of the other problems, but at least the car runs again. Thanks for the question. Now I have to see if there is a way to determine what went wrong with the modified rcm again!
