Old Sep 9, 2025 | 09:01 PM
M60A3Driver
Default Re: Illumination Control Module
Originally Posted by rctitus
Hi.
I'm installing a Jensen display for Android Auto and reverse camera functionality and it wants me to access the illumination control module to tap into the reverse gear signal (pin 3 or 4 on the black 21-pin plug) and the parking brake signal (pin 2 on the black 4-pin plug).
How can I access the illumination module with these 2 black plugs, supposedly in the instrument panel left of the steering wheel?
Also, I don't see in the shop manual a pin on the 21-pin plug for a reverse signal. I know this manual set is fraught with insufficient instruction, but this omission is alarming.
Thanks, Ron
While you're in there you might want to put a couple of inline fuses between the 2 large power wires. The post I made shows how to disassemble the dash step by step wit pictures. I put in two in line fuses for fire prevention.
Here's the post: LINK - Illumination module
You don't have to do this, it's just a suggestion.
