Old Nov 4, 2025 | 03:49 PM
pizzaguy
Default Re: Antenna and air baglight
Originally Posted by The Relic
Hello, I am a new member and a 2007 crosfire owner. I look to getting to know the other members.
I have two questions 1) what is the best replacement antenna. 2) what does my airbag light stay on.
The Relic
There are several antenna whip/rod options on AMazon that are good. You can even buy the entire kit of whip/mount/preamp/cable.
My airbag light has been on since 2016 when the AirBag module went bad. Mine is also a 2007, the 2007/8s have a different airbag module than the 04-06s; ours is very rare.
YOu must get a module from a parts car (as there are no new parts left) and have it reset by a company capable of programming - talk to Needswings.com or themercedesswapshop.com.
OR do what I did, pull the fuse so the warning light goes out and forget it. Airbags save lives only VERY rarely.
Just know that ANY shop that tells you they can fix this is full of BS, if you really want it fixed, find a used (but known good) module and talk to one of the companies above about how to get it reset for your car.
