nickwe21
Very curious. Seems like the SRT6 belt tensioner pulleys aren't available anymore. What do you guys do once it wears out?
Can the N/A one be substituted?
Also have heard split opinions. Do you use the E10 torx to release belt pressure or a 15mm socket (the screw behind the torx)?
I tried the 15mm and am afraid I actually loosened the tensioner? Might be in my head buts it has a slight wobble and had too much play imo.
Should I tighten that 15mm screw or should I tighten the 2 screws that hold it in place?
But more importantly, if these aren't to be found new anymore, what are you doing if it breaks?
Maybe Rob at Needswings.com can hook you up with one.
