Old Mar 16, 2010 | 06:16 PM
onehundred80
Default Re: Headlight headache...do you have water in you trunk?
There have been previous posts on trunk leaks, in one case the water came from the rear light and in another it came from a seam between the trunk floor and the side panel. I would also think that the rear window seal could be at fault allowing water to run down behind the bulkhead.
I have never looked in this area but there is supposedly a drain in this area and it was plugged with silt in one of the reports.
https://www.crossfireforum.org/forum...tml#post434389
https://www.crossfireforum.org/forum...tml#post436629
https://www.crossfireforum.org/forum...tml#post189889
