Old Mar 6, 2011 | 02:57 AM
SoftballJunnkie's Avatar
SoftballJunnkie
Default Re: New TSW Donnington's... *Pics*
J, so if im understanding correctly if the centerbore is greater then 66.56mm then I will need hub centric spacers correct?
So if its at 74mm I'll need a 10mm spacer to correct the issue?
Originally Posted by JHM2K
Not sure what would cause the wheels to vibrate... What size is the center-bore, by chance? I remember someone a while back bought some TSW wheels, and the store ordered him 72mm center-bore, but he needed 66mm. That slightest discrepancy in hub-centering caused a vibration north of 60.
I'll see if I can dig up the thread
**edit** Here you go:
https://www.crossfireforum.org/forum...d-balance.html
Also, a link in one of the last posts for an alternate place to order the spacers.
