Some have cut 1 full coil off and others have cut 3/4 to 1/2 coil off. You may have to use different combinations of differnt thickness (how many dots) spring pads to fine tune the final height.
https://www.crossfireforum.org/forum...ads-shims.html
It really depends on what wheel size, back spacing/offset, and tire size for rubbing. BrianBrave has a great write up that I found useful with details from other members as well;
https://www.crossfireforum.org/forum...tml#post162184
Velocioblast has done a great job listing different tire combinations he has used his wheel specs and lowered height.
https://www.crossfireforum.org/forum...-18-front.html
There are also many others that have lowered that list what wheel and tire combos they have.
https://www.crossfireforum.org/forum...et-wheels.html
If you get spacers make sure they are hub centric. MB is a different bore size than Audi or VW. After the spacers make sure you get the right wheel bolts or modify them so they don't thread into your hub further than 18mm.
https://www.crossfireforum.org/forum...heel-deal.html
https://www.crossfireforum.org/forum...lug-bolts.html
https://www.crossfireforum.org/forum...l-spacers.html
I used the wheel fitment guide in the sticky to fine tune spacers, wheel, and tire sizes.
https://www.crossfireforum.org/forum...ment-tool.html
I haven't done anything yet, so this is just info that I have found helpful trying to figure everything out doing research. sorry for all the links. Good luck.
