Re: Left headlight burnt out!!
Does the high beam work on that side? If it works check fuse #8 in fuse box that's on the side of the driver side dash panel. It should be a blue 15 amp fuse.
from searching "HEADLIGHT FUSE".. I'm sure you can find more, and I'm not positive this would be the only fuse...
