Old Apr 18, 2012 | 11:04 PM
pizzaguy
Default Re: Top lowering video...
Originally Posted by lildaddym
Ours came with a plastic window...whoever had the car before we did settled for that!
My letter shows the "Chrysler Customer Assistance Center" is open 8am to 8pm Mon-Fri and 9 ot 5 on Saturday.
CHrysler Customer Assistance Center
PO Box 21-80007
Auburn Hills, MI 48231-8007
800-247-9753
Hope that helps.
Anyway, 1,000 thank yous on the video. I saw the procedure in the manual, but somehow your video got me to go out and try it. I have the official emergency wrench, but they do NOT provide an allen wrench to start the process! I now have the right sized wrench in the flap between the seats with the emergency wrench. I put it down manually, but put it up electrically. In reality, I'd probably be putting it UP manually, but I get the procedure.
Also, mine did NOTHING when I tried to release pressure, but that makes sense, since in the NORMAL operation of the top, there is no pressure in the system unless you are putting it up or down. And even part way thru, if you stop the process, after about 10 minutes, all pressure is released anyway and everything relaxes - even if this means that the top is in a position where things should NOT relax!
Read about this in section 23 of the manual, mostly page 23-482!
