Top lowering video...
Old Apr 18, 2012 | 11:12 PM
lildaddym's Avatar
Default Re: Top lowering video...
My letter shows the "Chrysler Customer Assistance Center" is open 8am to 8pm Mon-Fri and 9 ot 5 on Saturday.
CHrysler Customer Assistance Center
PO Box 21-80007
Auburn Hills, MI 48231-8007
800-247-9753
Hope that helps.
Anyway, 1,000 thank yous on the video. I saw the procedure in the manual, but somehow your video got me to go out and try it. I have the official emergency wrench, but they do NOT provide an allen wrench to start the process! I now have the right sized wrench in the flap between the seats with the emergency wrench. I put it down manually, but put it up electrically. In reality, I'd probably be putting it UP manually, but I get the procedure.
Also, mine did NOTHING when I tried to release pressure, but that makes sense, since in the NORMAL operation of the top, there is no pressure in the system unless you are putting it up or down. And even part way thru, if you stop the process, after about 10 minutes, all pressure is released anyway and everything relaxes - even if this means that the top is in a position where things should NOT relax!
Read about this in section 23 of the manual, mostly page 23-482!
I made the call over a month ago to Chrysler...my case worker turned me down, as did the person I appealed to...wrote directly to the CEO, Sergio Marchione...nothing has helped so far...
As for the video...not a problem...been meaning to do it, had the time yesterday...got a lot accomplished, including fixing my top, and solving a problem with the tonneau flaps that get some paint chipped off...
Old Apr 19, 2012 | 08:37 AM
smfrycruzr's Avatar
Always wondered how that was accomplished. Thanks for the Vid.
Old Apr 19, 2012 | 03:38 PM
Originally Posted by lildaddym
Call it done! Give me a bit...
Hey it worked with the new viewing program! Thanks Bro! Appreciate it! Looks pretty easy too!
Old Apr 19, 2012 | 03:40 PM
lildaddym's Avatar
Thanks for the kind words, young man...sorry it took so long to find something that worked for you!
Old Apr 19, 2012 | 05:35 PM
Ok, so the most likely "top Emergency" would be that the top wont go UP.
Ya gonna do a video of putting it UP? I can - I just put mine up manually, all by myself - didn't think I could do it alone, but you can.
I might go do it, then if you do as well, we can compare and see which we like best. But I have no way of adding text yet ( or do I?)
Old Apr 19, 2012 | 06:22 PM
lildaddym's Avatar
I could do that...my issue is how to make sure things lock...I don't know if that's covered in the manual!
Old Apr 19, 2012 | 06:29 PM
Two comments on the video -
1. it is easier to unlatch the tonneau from the outside by lifting the rear window bow for access,
especially if you have a wind restrictor.
2. at the end of the video, you walk away like you are done. YOU AIN"T !!! If you do not relock the tonneau, you are in for a very expensive surprise when you hit a bump doing 60 .......
Old Apr 19, 2012 | 11:43 PM
lildaddym's Avatar
Maybe I didn't make it clear in the video text that you need to lock the tonneau down...I've never done it manually...sorry I missed that!
Osusannah
Feb 12, 2024 01:49 PM
Valk
Jul 12, 2021 09:49 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
