Old Apr 25, 2012 | 10:23 PM
James1549
Default Re: Crossfire turns over but wont start
Originally Posted by texasboy_11b
sorry about that should have been a little more specific about the crank and not crank, it takes like 3 to 6 try's to crank if I am lucky. When it cranks I am not able to drive it because of lack of power. We did test the pressure and all before replacing the fuel pump and filter before we changed them but that didn't fix the issue. Battery is good. Also from what i have heard is the CPS goes out when it gets hot.
And what was the pressure reading that caused you to replace the pump? And what was the reading after replacing the pump?
James
