Old May 1, 2012 | 03:59 PM
nate_man's Avatar
nate_man
Default Re: O2 Sensor Replacement
Originally Posted by Ken Hales
I had the engine light come on and took it to a dealer in Vancouver, Canada. They told me it needed an o2 sensor at a cost of $800. I purchased a INNOVA Dianogstic reader and it showed a code 'P2098'. Based on that I replaced the Post Cat Bank 2 sensor ($120) and cleared the code. 50 miles later the same code triggered the check engin light.
I don't understand the O-Ring thread since the Post sensor compares readings after gases pass throught CAT to readings before the gases passes through the CAT ; checking the performance of the CAT. Can someone please explain?
I am not sure about that code as my O2 was a p0168 code. I am not sure if that is for the downstream sensors. My sensor was the drivers side post cat sensor.
I am not familiar with the p0298 code.
ANyone else? Are these codes pre-cat codes?
