O2 Sensor Replacement
Old Oct 26, 2012 | 10:11 PM
  #41 (permalink)
Fastrg's Avatar
Default Re: O2 Sensor Replacement
05" Roadster. Upstream sensorbad , noted by dealer....COST $740....Will never go through that again. 4 months later light is on again. Went back to dealer. They told me it is not the one they replaced. Cost $75 for scan, Dealer said for another $700 they would replace it . I said "screw you". Went to a neighborhood shop , he said go to Auto Zone & get one for $120 & they put it on for $30....Dealerships are like gangsters....
Old Sep 1, 2014 | 09:46 AM
  #42 (permalink)
Sesontcket's Avatar
I had an upstream O2 sensor code reset and now the check engine light is off, however I figure it's just a matter of time before it's back so I am going to replace them. I was wondering if I could get some advice on the cheap sensors I see on ebay. Has anyone used these? Do they function properly, or should I just bite the bullet and pay the Bosch price? I'd appreciate any insight or feedback.
Old May 29, 2015 | 06:12 PM
  #43 (permalink)
tednite's Avatar
Ok...Lots of stuff about "codes" and how much it cost. What I want to know is for the two upstream sensors...where the heck do those wires go into the firewall?
Old May 29, 2015 | 09:56 PM
  #44 (permalink)
They don't. They go into the harness in the protective sleeve and run to the box next to the battery that holds the PTCM, BCM and RCM.
Old May 30, 2015 | 05:16 PM
  #45 (permalink)
tednite's Avatar
Thank you Pizza Guy. Many times the information is so convoluted that for us novices, we are lost. And the more we are reading into a 'thread', the more lost we (I) become. Simple answers are the best until we begin to reach the point you 'educated, experienced' owners have. I just want to enjoy my car without spending a more than is necessary, yet keep it running smoothly.
Thank you.
Old Jun 2, 2015 | 11:36 AM
  #46 (permalink)
tednite's Avatar
Thank you to all who replied about the O2 sensors. I will try to list it. I became a little scared when a repair shop said that "they saw that the harness was going into the firewall." And when I looked it did! But I'm hoping that the sensor somehow disconnects as a plug in. Wish me luck! I'll let you know.
Just one thing: with all of the pictures and info about various topics on the XFires, is there anywhere with pictures of the O2 sensors being changed? Or, pictures of where they plug into harness
Old Jun 2, 2015 | 07:35 PM
  #47 (permalink)
I have never replaced the O2 sensors, but I believe the cables on them are not very long. THere is a quick-disconnect plug in line, you've got to get the cable out of the protective sleeve I mentioned above to get to it.
ALSO, be very careful about what sensor you order. You want the "direct replacement" ones, some come with the cable, but not connector and you must then change the connector housings yourself. NOT a fun job at all.
Order the "exact fit" Bosch sensors. But don't change the sensors unless you KNOW that is the issue. Bad plugs or plug wires will cause the cylinders to miss, putting high levels of O2 in the exhast, causing O2 codes. This happened to me around 100,000 miles. 12 plugs and wires solved it.
Old Jun 9, 2015 | 10:41 PM
  #48 (permalink)
tednite's Avatar
Thanks again Pizza Guy. changed spark plugs, oil and filter, and clean ed and oiled air filter. Light is still on, so will try to find the quick connect for O2 sensor.
Old Jun 10, 2015 | 10:05 AM
  #49 (permalink)
syfi's Avatar
If you haven't done so already, do the RCM repair on the solder points. May just solve all problems.
https://www.crossfireforum.org/forum...-no-start.html
Also you may just need to reset the code to see if it comes back....
Old Nov 9, 2023 | 04:53 PM
  #50 (permalink)
Crow13's Avatar
Nate... '05 SRT6 coupe is running well, but popped a code P0133 says 02 sensor, left bank ahead of the cat. That code doesn't match what I've seen in the forum. Make any sense to you?
Appreciate the help/
Crow13
Old Nov 9, 2023 | 05:53 PM
  #51 (permalink)
Nate hasn't been on here since 2012.
PNA
Nov 12, 2020 04:44 PM
Adrian_X
Apr 8, 2020 02:36 PM
jgreen
106
Sep 18, 2017 11:46 PM
sittininthesun
Aug 24, 2015 10:47 AM
Mark McKay
Jul 17, 2015 01:18 PM
