Old May 2, 2012 | 07:47 PM
Mrmiata's Avatar
Mrmiata
Default Re: Front License Plate - 'No Holes' Wanted
Just took a look at mine.. |---
A bracket shaped like this to mount above the lower grill would work pretty good - two legs going back to "split around" the center vertical part.... holes would be on the bottom side of the nose and never seen when removed unless you were running over somebody. Something they should have done in the first place.. then I wouldn't have holes on the front of mine!
Thinking about it.. one could mount "shelf" brackets to the oem holder and achieve this...
