Old May 22, 2012 | 10:21 AM
onehundred80
Default Re: XF Coupe - Rear Diff Oil ?
Originally Posted by GrantB
Owners Manual says.
SAE Synthetic 75W-140
API GL-5
ATF is a bit thin if you ask me. I think the need is for an oil that can withstand high pressure between mating faces.
Re above, 75w - 140 is quite a high pressure oil, but wondering why it's thin ???
I understand the diffs on these XCF's are a limited slip diff.... if so, do they need a thinner oil to operate ?
most vehicles have a diff oil of EP 75 > 90...., so this one rated at 140 at high temp is good, but im wondering why it is so watery ???
I've used alternative oils to manufactureres recomended before and come a cropper & destroyed axles and gearboxes thinking I knew better .....
But I'm wondering at the logic of this ATF fluid in a rear axle . . . . unless it needs a thin oils for the diff lock to work ???
saying that, My landrover descovery uses a special ATF fluid in its main transmission manual box.....
But anything else simply was too thick and you couldnt change gear and the synchro simply would not allow u to change gear let alone put it in gear, and other oils would destroy a box in 5,000 miles totally.
Penny for your thoughts ??
Regards to all.
Grant B
I think you have misread the above statement, the 75W- 140 is a thick oil and is not an ATF, ATF is quite thin.
The OEM diffs are not limited slip.
