XF Coupe - Rear Diff Oil ?
Old May 21, 2012 | 12:22 PM
GrantB's Avatar
Default XF Coupe - Rear Diff Oil ?
Gents,
Xfire Coupe UK......
What Oil is recomended for the rear axle, and is there anything that any one recomends instead or cheaper ?
Regards
Grant B
Old May 21, 2012 | 02:51 PM
Mimi05SRT6's Avatar
Default Re: XF Coupe - Rear Diff Oil ?
I've had great luck with the AMOIL Severe Gear 75w-90. I guess it works well because I've drag raced over 500 times and still have the original rear end.
Old May 21, 2012 | 08:46 PM
arejohn's Avatar
Well I am going out on a limb here and guessing AMOIL ATF is auto trans oil. Probably designed for use in...you guessed it Automatic transmissions. Personally I would probably gargle with it before I put it in my rear end but I don't race. Use a gear oil. Synthetic.
Old May 21, 2012 | 08:59 PM
Mrmiata's Avatar
Kinda wondered about Royal Purple myself.. on the shelf at Autozone...
Originally Posted by GrantB
Gents,
Regards
Grant B
Owners Manual says.
SAE Synthetic 75W-140
API GL-5
ATF is a bit thin if you ask me. I think the need is for an oil that can withstand high pressure between mating faces.
Old May 21, 2012 | 09:00 PM
arejohn's Avatar
2005 Chrysler Crossfire Mercedes Gear Oil, Hypoid SAE 85W-90, Spec 235.7 001 989 17 03 10
The following material data sheet is interesting as in the beginning it refers to BP which I assume is British Petrolium and at the end of the sheet it states that it is a
Mobile document.
http://images.imcparts.net/shared/do...1989170310.pdf
Old May 21, 2012 | 09:18 PM
Mike1118's Avatar
500 passes says a lot.
Old May 21, 2012 | 09:22 PM
Mrmiata's Avatar
Yep.. tells me less than two hours run time and cool downs in between.. unless this is a daily driver too..
Old May 21, 2012 | 09:37 PM
Mike1118's Avatar
500 passes is 125 miles wot. Not many cars that can do that without at least one rebuild.
Old May 22, 2012 | 04:16 AM
GrantB's Avatar
Owners Manual says.
API GL-5
Re above, 75w - 140 is quite a high pressure oil, but wondering why it's thin ???
I understand the diffs on these XCF's are a limited slip diff.... if so, do they need a thinner oil to operate ?
most vehicles have a diff oil of EP 75 > 90...., so this one rated at 140 at high temp is good, but im wondering why it is so watery ???
I've used alternative oils to manufactureres recomended before and come a cropper & destroyed axles and gearboxes thinking I knew better .....
But I'm wondering at the logic of this ATF fluid in a rear axle . . . . unless it needs a thin oils for the diff lock to work ???
saying that, My landrover descovery uses a special ATF fluid in its main transmission manual box.....
But anything else simply was too thick and you couldnt change gear and the synchro simply would not allow u to change gear let alone put it in gear, and other oils would destroy a box in 5,000 miles totally.
Penny for your thoughts ??
Regards to all.
Grant B
Old May 22, 2012 | 05:56 AM
Mrmiata's Avatar
Nascar uses thinner oils for qualifying than racing.. Less resistance to rotating mass = more speed.. closest I can figure..
Old May 22, 2012 | 10:21 AM
Owners Manual says.
API GL-5
Regards to all.
Grant B
I think you have misread the above statement, the 75W- 140 is a thick oil and is not an ATF, ATF is quite thin.
The OEM diffs are not limited slip.
Old May 22, 2012 | 03:51 PM
Mimi05SRT6's Avatar
Oops my bad. Meant AMSOIL Severe Gear SAE 75W-90 Synthetic oil. The ATF is what I use in the tranny. Sorry about that. And my car is an everyday driver.
Old May 22, 2012 | 07:52 PM
Originally Posted by Mimi05SRT6
Oops my bad. Meant AMSOIL Sever Gear SAE 75W-90 Synthetic oil. The ATF is what I use in the tranny. Sorry about that. And my car is an everyday driver.
I have 2 sets of perfectly good spider gears if you ever need them...lol....
Old May 22, 2012 | 11:11 PM
04Fire's Avatar
I changed my rear diff oil first at 47,000 miles with mobile 1 75-140 (it was burnt!). I just changed it for a second time at 67,000 miles with royal purple 75-140 (not as burnt as the first time)... the royal purple seems to have toned down the rear end "whine" these diffs are known for.
Old May 22, 2012 | 11:15 PM
Mrmiata's Avatar
Cool deal!.. mine has the light "whine" so guess I'll be visiting Autozone for the Royal treatment..
Old May 23, 2012 | 07:03 AM
Mimi05SRT6's Avatar
Great to know Doc...Thanks!
Old May 28, 2012 | 04:41 PM
coolx's Avatar
Hmmm? - I'm glad I stopped in on this thread. Last tuesday I was on I10 west cruisin between 70 and 90 without the radio on and everytime I accelerated I noticed a sound from the rear-end, but I could not distiguish it from a whinning gear or the exhaust note. My Crossfire has 55k+ miles and I put 4k of those miles on since I bought it last September. I do not know the condition of the oil, but I guess I should check...thanks guys for the posts - always grateful for the Forum
Old Apr 29, 2013 | 01:09 AM
bdh's Avatar
bdh
Default
So no Additional friction modifier is required is that correct?
Old Apr 29, 2013 | 06:12 PM
harbor's Avatar
My owner's manual calls for 75w-85, so, like Mimi, I've used Amsoil 75w-90. Did I miss the memo on 75w-140 for the diff in my '07 NA?
