SRT6_Roadster
Don't put the green goop in your tire. It is not worth the problems it creates. If you do happen to put it in make sure you tell your tire shop as it can serious problems.
Best thing to do is use an air pump to get home or to the shop. If that does not suffice tow it to the tire shop.
As a side note guys.. I learned the hard way (1/2" dia x 5" long bolt through the rear tire AND wheel) it wouldn't be a bad idea to have a Mercedes OEM rim and tire stored in the garage. Even if you only ruined a tire.. seems most places have to order in the 19" ones unless you get lucky and find a used.
