Old Jun 25, 2012 | 08:38 PM
onehundred80
Default Re: Spark plug nightmare
Originally Posted by chuckg
ok / afraid to drive it anywhere to get a code until the engine service light goes off....the thing that bothers me is that it was fine before i changed the plugs....No Service Engine light was on, and the car ran just fine, just needed to change plugs and changed oil....so that is what i did...i did nothing else / going to try to gap the plugs and see if that will change anything, the car has the right amount of oil. thank you again
Did you connect the coils up correctly, I am not sure if you can plug the coils in wrongly, the cables may only fit in one spot due to the length of them, but this is a classic symptom of the wrong firing order being set up. Can you post a picture of the cable connections to the coil pack from the main harness?
