Old Jul 1, 2012 | 07:06 PM
  #431 (permalink)
pizzaguy
Default re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by Mopar or No Car
How far do you have to drill out the pin? I have drilled it out past the enclosing black sleeve so the assembly freely turns and moves laterally and the key still does not turn. Do I have to go in further?
Thanks.
I wish I knew... never had to drill the pin. I THOUGHT you were drilling the pin to you could take the assembly out.
BUMP!
Someone answer his question, cause I cant'!
(Ill go read the instructions and see if I can figture it out.)
