Old Jul 17, 2012 | 06:00 PM
  #467 (permalink)
pizzaguy
Default re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
From what I saw when I fixed mine, the only way to avoid the problem is to perform the mod BEFORE it fails.
And IF you wanted to try lubrication, it would mean going thru the WHOLE procedure anyway, since you can't lube the mechanism without popping the access cover off!
