Old Jul 23, 2012 | 02:41 PM
  #1204 (permalink)
amx1397
Default Re: *Needed* 20 to Pre-order Wavetrac LSD for SLK32/SRT-6
Originally Posted by JesseJamessrt6
I have noticed in my srt6 stock that when accelerating hard the rear "sways" or "drifts" slightly from side to side in a slow controllable way. It isn't the traction control because it does it with and without the traction control. The tires are not spinning when it does this either. I checked everything under the rear (control arms, sway bars, etc...) and everything appears to be solid. Do you guys think it is the traction/power switching between sides? Has anybody else noticed this before the install of LSD?
I had mine checked three times, then one day I was put in the the slicks on the car and as I was tightening it down I noticed the wheel move forward and rear, and this is after three mechanics check it out so after the tire was tight I took a big rubber mallet and I banged on the front of the tire the top of the tire and the sides of the entire to see if there was any movement up down the front or rear. There was movement that I checked all the bushings and found one or two that were a little bit worn out you could move my hand but when you hit it with a mallet, that's when you find it good luck..your car should not sway one way or the other when you're in acceleration it should be straight as an arrow jim
