tunaglove
Rudy, do you think this would net the same power as the 185 since it does not overdrive all the accessories (water pump, alternator)?
I know that the faster you spin the water pump, the less volume it moves due to cavitation. That cavitation should make it spin easier but at the same time, it is probably power neutral due to taking more power to spin it faster but not having as much drag on it at the higher RPM. Make sense?
