rcompart
As I've only put 10k on this bearing, it's honestly not yet known. It feels as good as the day I installed it though and it is an NSK bearing that is rated the same or better across the board as the replacement for the oem bearing. They are not as easy to locate from the various sources the stock one can be found due to its much broader use, but they are an off the shelf bearing that can be ordered when needed.
Perfect....thanks for the quick reply.
