Old Aug 15, 2012 | 10:08 PM
BadSRT2005's Avatar
BadSRT2005
Default
Originally Posted by oledoc2u
traction control off. put it in 1st, pull up to the staging lights, once staged brake torque to 1500 rpms, launch by foot to the floor releasing brakes at the same time. The car will shift even if you don't although when it shifts I pop that gear, it shifts I pop the next gear, and you should cross the finish as it hits 4th...I do a short burn out to clean the tires prior to staging... Just takes a few practice runs for you to get it done...
Thanks for the walk through, cant wait to try that out! One thing i dont understand is the pop? It shifts on its own from 1st to 2nd then you immediately pop it to 3rd, and it redlines 2nd and shifts to 3rd then you pop it to 4th it redlines 3rd and shifts to 4th then crosses the line! Is this correct?
