Old Aug 21, 2012 | 08:05 PM
  #1208 (permalink)
32krazy!'s Avatar
32krazy!
Default Re: *Needed* 20 to Pre-order Wavetrac LSD for SLK32/SRT-6
Originally Posted by Billy22Bob
can someone tell me how I work out the following Q re fitting a wavetrac to my SLK32
Q from Devin at Unitrax ....
We need to confirm the style of output shafts. Do you know if you have the "push-in" style output shafts or the "bolt-in" style? If you have the "bolt-in" style shafts, we will send you the orings and circlips required for the installation. Additionally, you will need to have the output shafts machined slightly. The "push-in" style output shafts require no modifications....."
Get under the car - have a look - maybe take some photos....
give him my VIN....
hmmm
Look under your car. if you have the 1 peice half shaft going from the diff to the wheel hub you dont need anything other than the wavetrac. if you have the 2 piece half shaft you will see a bolt pattern close to the diff. it allows the diff to be removed without removing the axles. then you need the circlips and the spacers from unitrax
