Old Sep 1, 2012 | 01:18 PM
  #950 (permalink)
Beaner's Avatar
Beaner
Originally Posted by amx1397
no one puts the batt on the right side because the air pump and the Electronics that operate the locks along with the vacuum that's in that corner if you put a battery of their the fumes would prove your electronics and your pump, better to stay on the left side(drivers side.) that's why.
Seperate than where the pump is located. Pump is under the carpet/floor area, Where I mentioned is behind the wheel. not the same, No fumes near pump. Just the hoses and a few wires pass through that area. It was just an idea
Anyways I got the covers painted and installed so I can drive it this weekend. I will be adding black paint to follow the lines through and hopefully it will look better than just solid SSB
