Goldwing
Just turn the key and let go...it should continue to crank and start "by itself". That's even cooler than push-button start.
The key system tends to fail when you least expected and it won't work until you pay $1500 to Chrysler to fix it or drill the key system yourself and re-search which is the best push button to use because if you put the original key system it will fail on you again :-(
