Push button start
Old Sep 10, 2012 | 07:07 AM
Chillywilly's Avatar
Default
I suggest that you take the time to re-read the ignition key fix if you have read it all ready or read it for the first time if you have not. You will learn that once it is fixed it will not fail again. You still need the key to be turned before you press the button or nothing will work.
The fix does not put the key system back to the set up where the locking key problem occurs, unless you replace the parts that are prone to failure but why would you do that?
But maybe you know more than anyone else here.
Ok I forgot to mention the Chrysler crossfire and the MB Slk the key system came from have a well known failure. The wear and tear of the lock will lock and you can't use the key to unlock the stearing wheel at all and Chrysler will charge $1500 to drill and replace the key system for you but they order the parts from MBz I had to pay a tow truck to take it to my house and I drilled it myself. I can turn the car on with the screwdriver but I can never lock my steering wheel and I have to put my key on the sensor. That gets anoying after a while so we need somewhere to just place the key and push start it. Im new at this lol so that's why I wanted to put my info I know someone has a better alternative.
Old Sep 10, 2012 | 07:44 AM
6000rpm's Avatar
Default Re: Push button start
When I had my stuck steering wheel fixed, I asked the tech to cut away the pin that locks the steering wheel. I guess I'll never get stuck in the parking lot for that reason again, but I can't lock the wheel which is OK with me.
Old Sep 10, 2012 | 08:03 AM
plenty of info here to help. Too bad you didn't see the sticky key write up before you tore into it.... I need to do my roadster soon....she is getting pretty loose...
Old Sep 10, 2012 | 10:27 AM
When people take a chainsaw to a flower garden, its difficult to understand the complaint the garden looks like crap afterwards. Doing the MOD correctly before you or someone else either ***** it up or charges you will give you a 100% functional repair that will not happen again (unless its forced and you break something during the fix). Please don't rant on the awsome fix just because you didn't have it or didn't do it right.
Push button starts for the crossfire are available, just do not expect it to work like the others or else you may be highly disappointed. A lot of specialized things need to be done to get it working up to maybe tearing apart a key for the chip, or completely bypassing the 'iggy ring' portion of the security system.
jhansen
21
Feb 15, 2017 04:26 PM
LE Cross
Oct 17, 2016 06:35 AM
glover
U.K.
Oct 1, 2015 03:34 AM
gtjl
17
Jul 22, 2015 06:28 PM
66L72M21
Jul 15, 2015 04:23 PM
