Old Sep 10, 2012 | 05:59 AM
onehundred80
Default Re: Push button start
Originally Posted by Chillywilly
The key system tends to fail when you least expected and it won't work until you pay $1500 to Chrysler to fix it or drill the key system yourself and re-search which is the best push button to use because if you put the original key system it will fail on you again :-(
I suggest that you take the time to re-read the ignition key fix if you have read it all ready or read it for the first time if you have not. You will learn that once it is fixed it will not fail again. You still need the key to be turned before you press the button or nothing will work.
The fix does not put the key system back to the set up where the locking key problem occurs, unless you replace the parts that are prone to failure but why would you do that?
But maybe you know more than anyone else here.
