Old Sep 11, 2012 | 07:07 PM
onehundred80
Default Re: Airbag light is on
Originally Posted by oledoc2u
Pay close attention all of you. If the light is on, your air bags are off. None of the system will work. The only way to turn it back ON is the "the dealer". It takes the Star system they use to reset everything. You can't do it. Someone while working on your car may have unpluged an air bag. You can only do that if you disconnect the battery first. Either way. A trip to the dealer will fix it if there truely isn't something wrong....but right now, you have zero safety features
That would be my answer too, you have to disconnect the battery before tacking the air bag wires off. The light would come on immediately though, not two days later.
CF448 does not give any specifics so no help can be given in that case.
