Old Sep 13, 2012 | 07:55 PM
pizzaguy
Default Re: MIL Codes after washing car?
Originally Posted by wraith13
Alright, but if the code reader will not reset them and disconnecting the battery will not reset them, what is the proper way to do it????
Page 25-37 of the Manual under "ON-BOARD DIAGNOSTICS" it tells you that a DRBII will erase the codes.
But again, depending on the code, they will go away on their own.
"After three good trips, the MIL is turned off. DTCs are erased following 40 warm-up cycles if the component does not fail again."
But I'm sure you can take it to your dealer and they will clear the codes ... for probably $60 to $150
My local guy does it for free.
