Old Sep 19, 2012 | 02:10 AM
onehundred80
Default Re: Airbag light is on
Originally Posted by 180SRET
Dealer called back, says there 2 codes, one for the module and one for the pass. side bag, however 1 code would cause the other code. If its the module, he's saying $2900. The cars an 04 with only 20200 km,s (around 12500 miles). I think its BS that a major safety system goes TU. This seems to be an issue as I'm not the only one ( thanks, search button!). They have my car overnite to try to narrow it down. Will post later.
Gord
I think this is BS as well, why would a "module" go bad after all it's never been used.
Probably a bad connection. Get them to give you the code, do not be too obvious about the question, just ask in a dumb manner and then check the code against the codes here. It's a pity you cannot get the code for yourself but some codes are only readable at the dealer.
