Old Sep 24, 2012 | 09:19 AM
PurpleNurple's Avatar
PurpleNurple
Default
Thank you SO much! This was a huge help.
Originally Posted by mikenewb
Found on the forum a way to program it that worked for me!
The Remote Keyless Entry Transmitter(s) can be programmed by the customer without special tools.
PROGRAMMING PROCEDURE
Transmitter programming by the customer is done by performing the following steps:
  1. Insert the key into the ignition switch.
  2. Press either the lock or unlock button momentarily twice.
Turn the key in the ignition switch to the ON/RUN position within 30 seconds.
Hope this is useful and saves you $100.
