Old Oct 14, 2012 | 11:49 AM
Mrmiata's Avatar
Mrmiata
Default Re: Help! My Crossfire Roadster won't start!
Originally Posted by oledoc2u
Skreen....haven't heard of this issue for awhile...Skreen module threads are on here somewhere...about starting running then dying.. Does it idle rough when it does run...as a problem with the crankshaft position sensor will do? That is a cheap fix if it is the CPS. But it may be the other problem which isn't a quick or easy fix.... So, without rambling on, I would replace the CPS...first...
There is a safety switch on the clutch peddle. It must be functioning properly as well...depress clutch all the way down as well...
Okay may be way off base here.. but when towed home.. was the tow switch enabled? I don't know if that would enable the anti theft or not .. but just a thought.
