Re: wanted lambo door kit
Rv Xfire08
I was thinking they may help me get in & out with my bad knees. I did get in a Lamborghini at the euro fest show and it was much easier to get out of. If we do decide they would only be on my coupe not Allen's roaster. That's for the in put. Joanne
The real Lambo doors are very light and thus very easy to use. Add 100 lbs to the door and opening them while you are sitting down in the XF is difficult and will strain your muscles, even with strong hydraulics. You also have to reach out and up to pull down the doors and gently so the doors do not bounce when they hit bottom.
My daughter did not even lift the doors. She would open the door to the first hinge and get out. Also you will lose the washer fluid container, unless you want to cut it and reseal it.
You will be getting in and out of the XF the same way whether you have or don't have the lambo doors.
Randy
