Old Oct 24, 2012 | 11:10 PM
  #405 (permalink)
Mrmiata's Avatar
Mrmiata
Default Re: How to Repair Relay Control Module (RCM) - (Mystery no Start)
Originally Posted by msheredy
Don't be so sure on the neglect as I had lots of corrosion too. I happened to notice a hairline crack in the battery's plastic case at the neg terminal so I'm sure some juices were seeping out and causing it.
I ended up going with Needswings small battery and it's been great.
Word to the wise though, when using baking soda to clean the terminals remove all hardware cause that chit will gum up and seize the bolt/nut that holds the terminal. I got way lucky and was able to remove the nut but I spent the next 30 mins with an xacto cleaning out the threads of the bolt and nut.
My fingers are crossed but I won't know until tomorrow when I get to work (where I had to leave my car) whether or not this fixes it. Just incase, and because I had nothing else better to do, I picked up a CPS too LOL!
Bosch I hope.. .. but have had good luck so far with the Adv. Auto version. Worst case it can ride with you for peace of mind.. LOL
