Thread: Key fob dead?
Old Oct 29, 2012 | 04:37 PM
onehundred80
Default Re: Key fob dead?
Originally Posted by Onlybiff
Hey all, new here obviously but used the awesome PDf to fix my key not turning issue. My new problem is that my key fob won't unlock the car remotely, it's 8 years old so I figured the battery's were just dead. I replaced them and it still doesn't remotely unlock the car and when I manually use the key it unlocks but the alarm goes off and when I try to start the car it fires right up then shuts down virtually immediately. Anyone go through this before and have suggestions? Thanks for any help in advance.
Jeff
Chicago coupe owner.
Did it fail when you started the car after fixing the ignition problem? If so you may have not reattached or broken the halo ring wire or pulled it off its connector at the SKREEM module.
Look there first, it's been done before.
