Re: More Volume
Maybe I'm in left field.. but if you replaced the amp with a 4 channel amp and split the signal (like oem does).. you wouldn't basically have the same setup with a more powerfull amp? Add base blokers - filters as required at the input to the amp..or output.. Not a "top notch" setup, but lets you retain the oem HU and crank it up a little more..
