Mrmiata
Maybe I'm in left field.. but if you replaced the amp with a 4 channel amp and split the signal (like oem does).. you wouldn't basically have the same setup with a more powerfull amp? Add base blokers - filters as required at the input to the amp..or output.. Not a "top notch" setup, but lets you retain the oem HU and crank it up a little more..
The stock amp has more than just audio crap going to it. Thats not even taking into consideration what everyone else said... The biggie, heat. If you find one that works, let me know. IMO if you want to put in a 6 channel- which is what you need, not a 4.... then let me know how it goes, I cant think of anything that would work, and Im not convinced its a good way to go.
lildaddym
Which Kenwood do you have?
Kenwood KDC-HD548U (KDCHD548U) In-Dash Car Stereo w/ HD Radio ----I believe I have the older version of this. Not sure exactly I will need to look.
-This weekend was spent putting in a 1/2 farad capacitor for testing purposes.
