JesseJamessrt6
I think you should should replace the rear subs with regular speakers. The OEM amp is 4 channel. Beware that the rear cannels of the OEM amp are set up to run dual voice coils. There is no aftermarket 6.5 subs that have dual voice coil.
stryfox
Just a random thought. What if I put speakers in the factory sub location and just ran a traditional 10"sub in the back?
sk8erjosh09
If your deck has Center Bass Freq, High Pass and Low Pass settings for rear channels, then I would just clip the Rear sub wires at the amp and run them straight to your deck, bypassing the amp and headaches of wiring RCA's completely. The stock amp puts out 22W, my aftermarket HU puts out the same, and with the adjustments mentioned you would have enough control to make it sound good. Ask me how I know
Dual voice coils.. this is why I say break the amp into a 4 channel at the input side instead of output and bypass the amp.
If you are using an adapter to the oem stereo plug.. you can just pull a couple more wire leads from there to the amp for front - rear control and frequency adjustments if new HU is capable. If your HU has subwoofer outputs something like this will add the extra kick (link).. This setup isn't going to win you a trophy.. but you'll enjoy it more than stock. I would advise going this route.. with added amp and sub of your choice before spending more to possibly be dissapointed in the end. Basically break out the New HU - amp to 4 channels..no cost.. add the subwoofer and then spend away if you don't like it.
Infinity BassLink Powered subwoofer: 200 watts and a 10" sub at Crutchfield.com
My final .02 here...
This rides in my "trunk"..easy removal as required.. and adds plenty of bass thump.
