Old Dec 1, 2012 | 03:53 PM
onehundred80
Default Re: Low tire pressure light
Originally Posted by tjinaz
Discount tire put third set of rears on for me (96K miles for 3 sets total) and this is the first time the sensor has stayed on after about 100 miles. Took it back twice and they said they don't have Chryslers code to do whatever they have to do....Light went out for about 50 -100 miles and then went back on. Dealer will want probably about 80-130 bucks to "scan" and I keep thinking since it did go off for a while it might be a short from a wire? touching.
Any body with this occurrence?
Thanks,
tjinaz
Assuming you have the correct tire pressure in all wheels, then you should not have this problem IF the wheels were put back so that the sensor stayed in the same location as it was before. There is a chance you had a sensor(s) damaged by the installer or a battery coincidentally died at the same time as the tire change, which is too much of a coincidence.
I had my tires changed this past summer and the light did not come on at all. Why should it as there is no difference to the settings to what it was before the tires were changed. My tire installer asked if the sensors had to go in the same location as they came off and I said that they did.
