bluecoupe
Thanks Steve, good to know. Hmm, Rob (Needswings) recommends we torque spark plugs to 21ft/lbs, no mention of wet or dry threads.
NGK Iridium IX Spark Plug Set Stock Heat range
Many, here on the forum have suggested using anti-seize on the plug threads, but have made no mention of the torque spec. Assuming 21 ft/lbs is for dry threads, what should the wet torque spec be? Anyone know?
Steve, I think some are making mountains out of mole hills. Wet threads on things with such small torque specs should not make a difference to cause damage. Wet or Dry threads on spark plugs, use the torque spec and you will be fine. I prefer wet threads so I don't chance the possibility of removing threads from aluminum heads the next time I remove the spark plugs. Even at the torque specs of wheel studs, I don't see how it cause such an "over torque" to cause problems. On wheel tightness, I think equal tightness is more important than the actual spec (within reason).
When torque is super critical, the application usually calls for specific compound to be applied on the bolts. Such as "International Compound" has been used for years when installing head bolts, main caps, etc... on engines where large torque specs apply.
