Old Jan 15, 2013 | 04:16 PM
Mrmiata's Avatar
Mrmiata
Default Re: Starting issues and key fob?
Was it a coincidence that the fob would not work, Hmm.
Maybe not.
If these symptoms are linked then the problem may lie in the security system.
Does the second fob open the door?
Have you got water in the trunk? That would be in the passenger side well under the Styrofoam block.
Ahh... I read right past that "two starts and nada".. Disconnect battery..reconnect and try again..two more attempts and nothing.. then here we go time.. There's a rubber plug on the bottom of the car..rear of passenger location (under the styrofoam blocks mentioned).. "puncture" it and see if you get any water out of it.. The easy way to see if you have standing water right quick..
