Old Jan 27, 2013 | 05:51 PM
pizzaguy
Default Re: New Member - Need help
Originally Posted by ijaved
Hi all, just got 2005 crossfire yesterday and need some help fixing the water in the headlight. I took out the top two screws but the assembly wont come out. Read somewhere that there's 2 more under the light whats the best way to get to it. Or bumper has to be removed to get to it? its the driver side.
Also car was in winter mode and it went into tip mode and got stuck in 4th gear. I had to pull to the side turn it off and turn it back on after which it was working ? is this a common problem or can someone point me to right direction to figure out what that was? its Automatic and i dont feel any problems when it is changing gears. I dont plan to drive it in winter was just bring it home from dealer. Outside temp was around -12 *C.
I drive a 6 speed, not sure I've heard of the auto-thing you are describing. What is "tip mode"? I HAD an auto for a time, never had any problem with it other than the common transmission-fluid-leak-from-the-electrical-connector that everyone else has at least once.
I THINK there is a thread here SOMEWHERE talking about removing the headlight assembly... doing a search with the search button might do it, or search the "exterior" forum for thread titles about it - is all you can do.
Other than that, it sounds like you better go here and download the SRT6 Service manual (applies 99% to the N/A-Limited-Base models):
https://www.crossfireforum.org/forum...ollection.html
You will never print it all, but it IS helpful. Just hard to search thru.
